  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ahh buggered if i know, its running on all four now which is good but low and behold after its maiden run i open the bonnet and there is oil all over the place. there is a leak somehwere near of behind the CAS cover and its spraying all over.
The coke bottle worked good though ;)
Hopefully ill take of teh CAS cover and there it will be some little o ring or something taht obviously need replacing. Either that or a big crack down the side of the block :eek: might need an engine upgrade :eek1:
Yeh that is where its coming from. Ya know the little oil breather box thingy? we we ripped that off and replaced it with a CPU heatsink (dont knock it it works) and from the little gap next to it u can see it all come out. Alot of smoke too
hmm well im not at home and i dont have adigcam so there are afew obstacles.
Ya know the valley with all the plugs and crap? well there is a little flat bit of metal on one side and a little box that sticks out of the rocker cover and joins the breather pipes from the intake to the ahhh other thingy. yeh that part
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
