  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ahh buggered if i know, its running on all four now which is good but low and behold after its maiden run i open the bonnet and there is oil all over the place. there is a leak somehwere near of behind the CAS cover and its spraying all over.
The coke bottle worked good though ;)
Hopefully ill take of teh CAS cover and there it will be some little o ring or something taht obviously need replacing. Either that or a big crack down the side of the block :eek: might need an engine upgrade :eek1:
Yeh that is where its coming from. Ya know the little oil breather box thingy? we we ripped that off and replaced it with a CPU heatsink (dont knock it it works) and from the little gap next to it u can see it all come out. Alot of smoke too
hmm well im not at home and i dont have adigcam so there are afew obstacles.
Ya know the valley with all the plugs and crap? well there is a little flat bit of metal on one side and a little box that sticks out of the rocker cover and joins the breather pipes from the intake to the ahhh other thingy. yeh that part
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
