Originally posted by GTS-t VSPEC
Careful Cam, I'm know to call late at night and do heavy breathing:p
See'ya:burnout:
no probs paul - it'll be the most action i've had in ages! :P
man that sounds poor! hehe.. but it's true... *sob*
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
the **** look is for private viewings only. sorry to disappoint guys but im over the teeny bopper boob tube with shortest skirt possible stage - its either short skirt and full top or revealing top and jeans.
well.. i think i'd have to go with the revealing top and jeans..
as long as they are hipster jeans.. and there is a G on underneath..
hehe - so half and half hey niz?
paul - don't have anyone specific tuning my car.. a few have tried - but haven't been able to find anyone decent.. was going to try out PSI.. i know he's blown enginers - but some other people had some pretty good reports about him and i should be able to screw him down on price cause of the ITC wiring diagram he got from me which I can imagine will be worth $$ to him in the long run..
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
