Originally posted by GTS-t VSPEC
Careful Cam, I'm know to call late at night and do heavy breathing:p
See'ya:burnout:
no probs paul - it'll be the most action i've had in ages! :P
man that sounds poor! hehe.. but it's true... *sob*
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
the **** look is for private viewings only. sorry to disappoint guys but im over the teeny bopper boob tube with shortest skirt possible stage - its either short skirt and full top or revealing top and jeans.
well.. i think i'd have to go with the revealing top and jeans..
as long as they are hipster jeans.. and there is a G on underneath..
hehe - so half and half hey niz?
paul - don't have anyone specific tuning my car.. a few have tried - but haven't been able to find anyone decent.. was going to try out PSI.. i know he's blown enginers - but some other people had some pretty good reports about him and i should be able to screw him down on price cause of the ITC wiring diagram he got from me which I can imagine will be worth $$ to him in the long run..
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
