  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Well I'm not in any rush to sell just yet. It give you the luxury of seeing the car in action at cruises and the drags. Not to mention forum members spill their guts about whats happening to their cars all the time. So you can go past all my threads about how I don't clean inside my car and I take no care in washing it on a regular basis but, on the flip side I am very keen on keeping it in a good state of tune (hence the fast times).
Even if you didn't particularly like my car there are always oppertunites when other forum guys sell theirs (you can dig up plenty of history and opinions).
