  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
... so what do you wnat me to buy?
No expert, just don't trust sales droids, so I'm forced to do my own research :D
Honestly, if you're going to use your telly for sound and basic composite video for video, then a strathfield-priced player will do everything you want. CD/CD-R/SVCD/DVD/mp3s and region free at a low price. Like rev said, the mpeg chipset and board these players use (mostly zoran?) are off the shelf, so theres not much design for them to screw up.
If you're more of a name brand type person (safe way to go), then low end Panasonic and Pioneers would be my pick. Panasonic may not play mp3s but both should be region free (ask the salesman and bring a test disc just in case). Price for them should be similar ~$350. If you have a Myer or DJ shareholder card, ask them to price match and use the card. Otherwise, break the balls of a local retravision or hardley normal sales droid for a good price.
Originally posted by macka
how does that work?
Macka - DVD rom in computer which will play absolutely anything.. connect to tv via svideo output from video card.. connect to surround sound amp via optical output from sound card for 5.1 surround..
easy.. :D
Originally posted by caminperth
me out too.. time to do the long distance phone call thing to malaysia...
gonna cost me a bomb..
nite all
not as much as Korea... it cost me arm and leg every time I call me parents...
damm telestar they charge shit loads compare to other country telecom :):D
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
