  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
f'n'f is the most infuriating movie I have seen in a long time. If I learnt anything from it, it would be that people that liked it are effected by complete ignorance car wise. I mean....no a critique of it would take too many lifetimes.
The volvo is a family car. No nitrous for it.
The Skyline is a work car. No nitrous for it while I use it for work. If someone wants me to kit it before sale I'll sort it for them.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
