  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Gradenko
lol at the cow joke.
> So i sez "Listen buddy, your car was upsidedown when we got here and as for your Grandma, she shouldnt have mouthed off like that!"
Whats this from?
can you swing a sack of door knobs?
can I !!!
well, here's a sack. You'll have to supply your own knobs.
Originally posted by zanda
theres probably a trade off between a big nut that makes a bigger heat sink and is therefore better able to cope with extreme temps, and one which is munted already but is bigger.
too much info!! time for beer.. :D
will talk to u about it tomorrow bud.. we'll sort something out..
bye all..
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
