  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
those funcky vented front gaurds on GTAAH a little birdie said they are $1300 delivered and unpainted
nice but pricey
is that for a set or each skyzer?
also - anyone know where to get a good price on carbon fibre bonnets? worx have some wicked looking ones - but it seems that they have a superduper markup on them...
Originally posted by GTS-t VSPEC
Cam,
I can get them a bit cheaper, PM me if you interested:D
See'ya:burnout:
Paul - you seem to be able to get everything a bit cheaper mate! You got a container full of stuff hiding somewhere?! :mad:
hehehe *jokes*
what sort of $$ u talking? it'd be a "down the track but before car show" mod...
GTS-t VSPEC, I try to help where I can :mad:
skyzerr33, I didn't know yours was painted. Who did the job? I don't mind if mine starts peeling, only cost me a can of paint and a couple of hours of my time. If I have to do it again, I may go black with clear coat, gt-nik styles.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
