  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Cam,
Sounds like a good plan, but will it be ready for the show?
See'ya:burnout:
only major thing would be to do the rims.. might leave the wing on in hope of "bigest wing" prize.. :P
anyone got a set of rims/tyres they could lend me for a week?
Originally posted by skyzerr33
but ur a girl
Two words for that "yo momma!!!"
Gradenko drank something like a 1/3 of a bottle of "the famous grouse" then chased it down with a bottle of "the real macoy" so needless to say hes gonna be worse than me.
Originally posted by Adrian_perth
.... no rear wing for a while i hate the standard one!
have a chat to Zanda - he has one of the highish std one from a 95 sitting around - same as strich's one i think? you may be able to wangle a deal from him.. :P
troy
greddy := greddy/trust exhaust, greddy turbo timer
hks:- no
nismo:- no
hks should really be apexi lol coz i got apexi front pipe and nismo should be blitz hehehe coz i got blitz air filter but shit happens hey
adrian :P
Shuto-boy,
The PAS Western Salon, around October I think.
See'ya:burnout:
yea paul - i'm talking of being ready for that one...
bonnet, wheels and a bit of interior.. shouldn't take long.. :P
i am thinkin of taking the stickers off but i dunno hey maybe, maybe not we shall see!
hahaha aidwin? nandos skyline? man i wouldn't even be allowed into the car show with sumthin like that hehehehehe yeah i been thinkin of themes but still trying to figure out what i want!
adrian :P
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
