  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ahhh so u were misinformed about ur bov? hmmmmz not good!
paul doing work? unpossible hehehee anyways paul i found out how you find out about plates!
2. Plate availability
Want to know if the plates you want are still available? find out fast by calling our priority hotline on 13 11 56.
adrian :P
Originally posted by Adrian_perth
paul i got prices for plates!
custom series, aluminum = $275
custom series, polycarbonate =$375
7 characters for aluminium and 9 characters for polycarbonate!
adrian :P
thats provided you have a combination of letters and numbers.
all letters is extra- like $700
polycarbonate is what i have - then again you havent seen mine.
im here dark - just trying to clam down before i strangle indian lady who is annoying i'll b glad to see her back there on wednesday
hehe.. thats cool lauren.. how ya been?
whats with this indian lady?
