  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aw u home today shannon - im at work :D
Aidwin will pass on the sandwhich and other food stuffs.
As for dodgy foreigners probably haha my dad is going to taiwan in a couple of weeks so if this was after he came back i would be pretty suss!
GTS-t V-SPEC
Doesn't my sister drive ya crazy with her evo talk? I listened to her for half an hour wobble on about them on the weekend. I told her to shoosh cuz I don't like anything with triangle tail lights, JUST tryin to get her to stop. Of COURSE she had her Ralli-art hat on. She's a funny one.
Make sure you give to my Dad over his bald bit at the front! Give him a kick up the bum for the Pulser to. He used our money for that and now look where it is and has been sitting for so long. Then, after paying roteries out for years, he comes home with one? I can't work him out. I dunno, maybe you can.
If I can find a good photo I will stick it on here for all to see!!!!!
Everyone on this site can laugh at him then. That'll teach him!
R31 Chick,
Your sister is mad about EVO's and horses, she can't decide which she want's more:D
The Pulsar has sat in the corner for a while, but I think your Mum is going to use it for hill climbs one day.
The Chooky is being finished off so Evan can drive it, while he finishes building his.
Hope you find a photo:D
See'ya:burnout:
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
