  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
aw u home today shannon - im at work :D
Aidwin will pass on the sandwhich and other food stuffs.
As for dodgy foreigners probably haha my dad is going to taiwan in a couple of weeks so if this was after he came back i would be pretty suss!
GTS-t V-SPEC
Doesn't my sister drive ya crazy with her evo talk? I listened to her for half an hour wobble on about them on the weekend. I told her to shoosh cuz I don't like anything with triangle tail lights, JUST tryin to get her to stop. Of COURSE she had her Ralli-art hat on. She's a funny one.
Make sure you give to my Dad over his bald bit at the front! Give him a kick up the bum for the Pulser to. He used our money for that and now look where it is and has been sitting for so long. Then, after paying roteries out for years, he comes home with one? I can't work him out. I dunno, maybe you can.
If I can find a good photo I will stick it on here for all to see!!!!!
Everyone on this site can laugh at him then. That'll teach him!
R31 Chick,
Your sister is mad about EVO's and horses, she can't decide which she want's more:D
The Pulsar has sat in the corner for a while, but I think your Mum is going to use it for hill climbs one day.
The Chooky is being finished off so Evan can drive it, while he finishes building his.
Hope you find a photo:D
See'ya:burnout:
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
