yea - the tommy one...
am getting a hks exhaust cam pulley, catch can, dump & front pipe, cam belt and diff service.. also get the ITC and AFC tunned and try to get my EVC controller working properly instead of just using the bleed valve.. should all go together to make something that is a bit more tunable and smoother running..
zorst - i think it's got two mufflers.. still quite loud tho.. wouldn't want anything louder...
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
