  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My clutch is ****ed. the car is sitting the garage all locked away.
works out good cos i get a lift with my gf to work, easy....
gonna make some calls about a new one today...
gotta sell my notebook too. i need the cash for a new clutch!! know anyone that wants one ?
