  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yes daniel 25GTT can attest to the fact i have 3 pairs of shoes in my car haha i had to chuck them all in the back when i dropped him off yesterday.
Ive also got 3 jackets but no - its not so much what i will wear.
My car is my wardrobe haha see what happens when girls have sportscars we ruin them and make them all girly haha
haha yeah cars make good wardrobes. Poncho tho?
Hmmm - ive got 5 parking fines in my console along with perfume, deodrant, lipstick, ummm sunnies that i never wear and other crap haha. Got a pair of rollerblades in my boot.
