  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
whos having a bbq? :)
YOu are :( hehehe.... if you didnt already known that :(
ummm I dont know how to tell the location of your house...:confused:
what would be best way?
cuz I dont think you will like it if I put your address on the web :) I never put my addy on web:p
so what do I do with map of your place macka?
