  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Your lookin forward to meeting my ole Dad, the ex hippie now baldy!!!!!!!! No-one looks forward to meeting him, only to get there cars tuned is what they are looking forward too! Nah, he is pretty good at dyno tuning, you are taking your car to the best if you take it there!
no he meant stay away froim the guys on here cause your a 18yer old blonde! hehehee nad by the way ur older then me :)
i jsut remember i am second youngest, the youngest uy on here Boosted_RB26 owns a r32 gtr the basterd :D hehehe nah he cool!
troy welcome onboard the bourbon boat! hehehehe cougar? beam? or my good friend jack daniels?
anywho i am off to the gym now so whore yas later on!
adrian :P
if not i will see most of yous at como tomomrow at 12
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
