  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
ack my sausage fingers. i swear they make key boards too small
Psiker
lol.. are u serious?
"your fingers are too fat to dial this phone, please mash the keypad for your free dialing wand"
pretty much dark :D (whats your name btw)
jon - ahahaha i do that all the time
Psiker
P.S dont worry bout niz man shes cool wont be upset at all i think ur still the same person but with diff vital details :(
ny name.. is Tharaka [yes i'm serious]
hopefully lauren will be fine with it :D
camin - just ondering how bad will that stuff my handbrake if i do that??
/me hopes yolonde doesnt read that i want to try this
psiker
won't hurt the handbrake at all.. handbrake only works on the REAR tyres bud... as it's fwd, no damage to handbrake.. :D
trust me - i used to have one of those old skool box excels when i was 17... :(
oh.. u have the same name as gtst-vspec..
yea.. the bad thing is all the dumbass substitute teachers get it wrong..
and we have substitutes a lot.. coz some of my teachers are away from school to go buy cars, watch cricket.. etc.. (he drives an S500 and hes a teacher..)
tarraka, tharka, tarika, aaah
i must admit that one of the only posts i havent read is the ladies who own skryrines one. it got too big too fast and then i couldnt be bothered
Psiker
its kinda interesting.. but then it gets whorred a little while through(gtst v-spec)
but yea.. its ok..
and there is a new chick for u guys to hit on.. Angie
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
