  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
couldnt find these weights on wheels today - saw mag, saw tyre, saw shockies, saw metal rods, saw springs, saw cobwebs, saw little plate on mag with 10/10/10 on it - but that was about it :(
Originally posted by Micko
Sheesh - you're sharp tonight young lady - good work...don't reckon most ppl will get that one though
AS I said last night , that conv is buried and way barked it's use by date.
cheers
ken
haha yes it was meant to be subtle :( (and yes i do know the meaning of the S word) haha
Gee whiz old man - don't act like I'm the pain in the ass that I am - surely you knew that when you sold me a car?
Anyways, question is this: there is a shitload of piping on the GTR; balance pipes between the turbs, etc, etc. Makes working on the car tricky & ppl tell me that it is mainly for emission control - can you tell me what can go & what needs to stay in order for the engine to run properly?
Ahhh , sometimes it's so hard ....
Those little 10/10/10 plates means ypu have 30gms of weights on that wheel.
God you must be good , cos sometimes your SOOOO blonde.
hehehe
cheers
ken
I did a THOROUGH detail of the inside after that i lost all motorvation, looked for these thingies on wheels but couldnt find them - not that i had a clue what i was looking for in the first place - so i'll do the rest of the cleaning in bits n piece thru out the week - might even take train to work so car stays nice n clean once its done
micko im not sure which hoses u can remove in a GTR but i did a cleanout of my engine bay over the last 6 weeks and its made a big difference to appearance and i can see the oil filter now too! not to mention changing the spark plugs is no longer the 30min job it used to be with all the crap over the cams
hehehe
cheers
ken
oi i know more than the average female
Im still learning
and daddy only bought me the cars he never showed me how they worked.
ok so the plaque are the weights cos its bloody small if it is - or it just telling me i should be going looking for 30gm weights elsewhere on the wheel? 30gms - thats nothing how the hell does that give the problem im experiencing?
Sorry Micko , missed the :( on the end , wasn't meant to sound like you are the pain in the arse.Hehehehe
Balance pipes ??
A lot of the pipes are oil and water lines that run between the terbs and are essential for terb wellbeing.
Not much emission stuff around there ??
Don't know who told you that and YES , they are a pain to work on. That's why I'm getting the engine pulled ( yes , some thing else I pull as well Niz:D ) to do the terb swap .
cheers
Ken
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
