Originally posted by adam 32
hey ken, ive heard u know a bit about speedworks. do you know if they can tune HKS F-Cons now? apparently some bloke learnt from the JUN tuner how to do it...
It's Andrew Jordan and Glenn Sumich pwpt60secf.
Glen is the salesman and Andrew is the computer boffin who Mr Jun prolly showed in his broken engrish how to tune the f con.
Mr Jun thinks the f con is good and the Apexi Power FC is not so good.
Go figure.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Thanks Ken.
I was looking this arvo & there is a pipe between the inlets of the two turbos just near the compressor which I assume is a balance pipe. There is also heaps of crap under the plenum that must be useless. Also, there are pipes that go right over to the front where the bov's are. Seems over the top cos I was checking out an RB26 at the track today on an R32 & there was heaps of room under the boonet.
Originally posted by SHUTO-BOY
micko: theres even more stuff inside a gtst engine bay,.a jungle
hmmm trying to give my engine bay a scrub today cos as u know from looking under it theres sand dunes in there - but too many hoses and stuff got in the way so i thought bugger it i'll do it a day when i have patience :(
Fabio - shut up!
Niz , soory was just trying to get sarcasm points up while you lot were recovering from your nana naps.
5 gms can make a difference but each wheel is balanced individually so the weight will vary.
Only way you will know is to get them rebalanced or swap front to rear.
cheers
Ken
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
    • Also this is my garage ornament 😁
    • @TurboTapin hey man thank you for all the info! I am about to order my cd00a today for a rb25 neo s15 build I am currently trying to get the ball rolling again on 😁 what is wrong with the Collin’s adapter? Is the bellhousing machining 15mm because that’s how thick the Collin’s adapter is or is that universal across any I decide to go with? Also do you recommend any adapter in particular? Thanks man 😃
    • Nice, looks good. Is the roof painted or wrapped? Welcome!
