Originally posted by darK
yea.. i was kiddin with the "kun"..
yea.. i know he's korean.. i was trying to speak german.. but i forgot it all ;)
lol
hahahah good try...
should say more like "An nyoung Ha Sae Yo!" :)
and also "kun" or "con" in Koean means Sir ;):(
Jap and Korean have similar sound words :(
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
Mike dont wreck your car u only just got it going properly!!
I agree , don't **** with it until you are going to do some wholesale changes like aftermarket terbs etc.
Remember the ones at the track have no aircond , don't have to idle well , are running no airflow meters , hence no recirculating BOV's ... etc etc.
cheers
Ken
cheers
Ken
Sounds like my car :(
cheers
Ken
Hmmm...once again the voice of reason rings loud in my ears.
Thanks Ken - just want a clean looking engine bay & less pipework so that I have a chance of understanding what is going to what:uh-huh:
Originally posted by Nizmo
*sigh* but front and rear have been swapped I watched them do it!
Ahh yes , I know that , you told me last night. ( remember , I stalk you Niz and hang of every word you say.... )
Did the problem get worse after they swapped them and why did they swap them in the first place.
I am not having a go at you but as I also mentioned last night , one of the major probs with doing correct diagnosis is knowing ALL the symptoms and what was happening leading up to the prob.
cheers
Ken
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
