Originally posted by Nizmo
they did it all at once - took car for drive - came back handed keys to me
Niz , I am still not convinced it is not a balance prob.
Only other thing i can think of that causes the symptoms you are describing ( note the service adviser type , non committed type reply :( ) is possibly loose front wheel bearings.
If I can get some time , I can come to your place or you come to mine ( with a chaperone if you don't trust me );)
And we can do some inspection.
cheers
ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by adam 32
ken; revised question...
can andrew tune it? do you know what interface they use? cos theres no external output on the ECU itself
Mate , I have never seen anyone in WA tune one yet.
Jash had one in bigred and lumpy couldn't tune it so it was binned for an Autronics when the engine was put in GTAAH.
I think it is done with smoke and mirrors:bahaha:
Cheers
Ken
ps try pm 'ing steve sst for a tuners point of view. He'sa cool and will give you a reasonably straight answer.
yeah that would be good ken :(
What ??
good I come to you or good you come to me ?
I have a jack so the latter would prolly be better but bring someone with you ( aka Paul )
My wife is suspicious of what I do as it is and a gorgeous 6' 1" blonde calling to my place alone is not going to help at all:D
cheers
Ken
ok if u want me to bring paul i will - yeah i'll come to u - um dont know what suburb u're in but wil work that out later :(
Paul has whaled here b4 , he knows .
Ps , pm ed you
cheers
Ken
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
