  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
lol harass? or come on??
lol ken. u only have one thing on ur mind. ur giving the old men a bad reputation
Psiker
I don't mind the reputation but enough of the old:D
Cheers
Ken
ur the life of the party joe :D only guy i know who can cop a feel and get away with it :D we all know u were really awake
Psiker
He didn't get away with it:uh-huh:
Getting away with it is waiting till the feeller is drunk and the feellee is still sober.
Cheers
Ken
lol. where u in rocko recently? i saw a guy who looked kinda like u driving round in a silver line. looked like an R but it may have just been a kit
Psiker
Rocko , is that somewhere near freo.
lol No it wasn't me , I haven't owned a silver GTR...... yet
Cheers
Ken
marlows aggghhh!
Joe will pay - but im a calculating female i'll bide my time and strike back where it really hurts when its least expected!
Paul i just got my suspension fixed i think they'll be a little suss if i go in there 3 weeks later with another set shot haha :D
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
