  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hahaha we all in for 1000 hey? hahahahahaa un****ing believable who would have thought a lil page would be worth so much? hehehehehe :mad:
adrian :mad:
i'm gonna win, i'm gonna win (turns around winds up his nos bottle, checks nitrous pressure, over runs the start line has to reverse back like a loser) heheheh :(
Originally posted by GTS-t VSPEC
Niz,
your probably right, but this server is better than the old one:D
Dan,
If it's not raining I might, who from the RB's are going?
See'ya:burnout:
the G4orse supra will be there, i will go, ummm a few others am hoping ND4SPD goes!!! would like to see it... a few good ones but a few bad ones too, the event is mainly to have fun so you can expect a few 20 sec passes if not from me from someone else..also my friend with a semi worked EF xr6 not bad for a NA 6 hoping for low 14 on that one!
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
