  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
Dark your parents dont really have a say in it.. but they can make your life missrable.  Hang in there if you can
Funny thing is , you love your parents till about 10 , hate them till 20 ish , tolerate them till 35ish and then realise they are the only ones you got so love them dearly complete with all there faults till they go.
* sniff *
cheers
Ken
haha
Originally posted by skyzerr33
fine u can pick her up and bring her to the cruise
then let me drive the R hehe
Go back to MIRC :)
Nah , if I'm going to j/lup to pick up your baby , she stays in the R
* evil grin and disables door lock * hehehe
Cheers
Ken
eyebrow ring eh kyles? got a punk cat :) shouldve given it a little mowhawk hehe
Zanda - i went to two different schools - Kalamunda high yr 8,9 and Camrel College yr 10. I live not far from kalamunda as i said im a flatlander tho :)
I dont know - i really dont think going back to study is going to be beneficial for me - I prefer learning on the job - I have quite a resume for my age :)
Finishing school isnt the "thats it and end all"
There are other ways to go about things
I would have to agree with Kyles even tho i know its not the best attitude in life. The most inspirational people i know didnt finish school and they are quite high earners. Just because i failed algerbra or chemistry or some other useless subject i was made to learn - doesnt mean im going to fail life - never used them yet and thats part of the reason i didnt bother learning them is becaus ei couldnt see a reason too - important things like English and social studies, basic math - I was a straight A student.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
