  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i agree kyles...
however - i used to think that goin to uni was a complete waste of time.. till after being one year out i'm now earning about 3 times what a friend who works in the retail industry is earning..
somehow seems useful now.. just my 2 cents for anyone thinkin of getting back into study.. can be waaay worth it...
Originally posted by Kyles
I dont regret quiting school. Yeah its not the best attitude to portray to the younger ppl out there but it depends what they want out of life.
Kyles , look at it this way.
Some of the guys with the most money I know are involved in the manual labour industries.
It's all very well having a degree but someone still has to build the houses , make the pools , fix your car , repair your dunny and trust me , they don't do it cheap anymore.
cheers
Ken
Troy why do u have my joke to paul as a quote haha come up with your own material boy!
haha funny today i was sittin gon St georges tce in the line and the lights were red (yes i remembered to stop that time) anyway this guy in an old RX7 pulls up beside me and he wasfull on perving at the car etc anyway his girlfriend kinda catchs on what he's doing - sees me in the car get pissed off at boy haha I thought i would blow him away at the lights too just to make a statement - must admit my car rose to the occasion too - kept in first til 5 half grand - it'll usually change around 3 and half.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
