  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by caminperth
shutto - n1 racing? think i went there last time i was there... prices there are wierd.. real expensive for some bits.. real cheap on some...
ken - uni takes application, not smarts.. same as learning a trade.. agreed on the building of offices - but u do need someone to desing them first.. (sorry - i'm an engineer and old habits die hard.. :))
Cam , it does not take an engineer to build something.
Making it stay up is a little harder without correct design.
Cheers
Ken
haha Ken :) no its a good week - just thought u should know but its irratating me.
Im flattered u would go to so much trouble to find out where i live - but why dont u pay paul in sexual favours or money to ge thim to tell u where i live :) or u could go to the shops in high wycombe and ask them where Nizmo lives and they'll tell u
Originally posted by Kyles
Lounge rooms all changed around.
I wish this place was big enough to have a party
you got a carport and a driveway haven't ya ?
Yippeee , outside Party at Kyles.
no one with a name starting with T is allowed. hehehe
Cheers
Ken
how do u think he got his wife old habits die hard
tell that to the little jap engineer who slaved for years to produce your gtr.. :)
no engineer - no technology - no go fast gtr... :)
Niz , i could find out where you live from paul but then wheres the fun in that ?:)
The post below yours from Cam sums it up . hehehe
Cheers
Ken
just kidding again.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
