Originally posted by caminperth
tell that to the little jap engineer who slaved for years to produce your gtr.. :)
no engineer - no technology - no go fast gtr... :)
Hoy , don't cut my post to suit yourself !:)
In context with the next line
Making it stay up is a little harder without correct design
is an acknowledgement that engineers are needed.
What the guts of this little post session is that we all need each other but young people these days think they all need a degree in something when a lot of them will never get a job in that field anyway.
Sometimes if you ain't got , you can still earn a good living by manual means.
cheers
ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Alex u ever see a old school 300ZX around with the plates Nizmo around those parts - one of my friends lives in pickering brook and i used spend a lot of time in the ZX up in kalamunda but now my friends have either got their licenses or moved back down to flatland etc i dont take the line up their often.
Um left school at the end of 98 beginning of 99. I was suppose to be in the class of 2000. Im 19 going on 20 in may.
true - sorry for that but that first line was begging.. :) no hard feelings at all.. i think alot of the people building the things around us.. and it does take an art.. but again, it's like anything - there's a few good ones who carry the rest of the mediocre.. i wouldn't go glamorising some guy who can weld stuff or use a spanner..
i agree with you that both professionals and trades need each other.. not sure if i agree with what you say about people not getting jobs in their fields - unless you're talking about arts degrees... sorry - got a pet hate of those "do my 5 years of study for my degree to get nowhere" people.. no offense meant to any of you who may be this type of person.. :)
cheers
ken
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
