Originally posted by caminperth
tell that to the little jap engineer who slaved for years to produce your gtr.. :)
no engineer - no technology - no go fast gtr... :)
Hoy , don't cut my post to suit yourself !:)
In context with the next line
Making it stay up is a little harder without correct design
is an acknowledgement that engineers are needed.
What the guts of this little post session is that we all need each other but young people these days think they all need a degree in something when a lot of them will never get a job in that field anyway.
Sometimes if you ain't got , you can still earn a good living by manual means.
cheers
ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Alex u ever see a old school 300ZX around with the plates Nizmo around those parts - one of my friends lives in pickering brook and i used spend a lot of time in the ZX up in kalamunda but now my friends have either got their licenses or moved back down to flatland etc i dont take the line up their often.
Um left school at the end of 98 beginning of 99. I was suppose to be in the class of 2000. Im 19 going on 20 in may.
true - sorry for that but that first line was begging.. :) no hard feelings at all.. i think alot of the people building the things around us.. and it does take an art.. but again, it's like anything - there's a few good ones who carry the rest of the mediocre.. i wouldn't go glamorising some guy who can weld stuff or use a spanner..
i agree with you that both professionals and trades need each other.. not sure if i agree with what you say about people not getting jobs in their fields - unless you're talking about arts degrees... sorry - got a pet hate of those "do my 5 years of study for my degree to get nowhere" people.. no offense meant to any of you who may be this type of person.. :)
cheers
ken
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
