  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
where did they go kalamunda or carmel?
I was pretty quiet when i was younger - well not quiet actually but lets just say a lot more naive and innocent than i am now so i doubt they got that much dirt.
Alex your folks arent scottish are they?
Aidwin - sweet i thought u were a bit older than me. Going to party for your birthday?
Originally posted by zanda
haha
rofl@cam.
"I hate those useless leeches.
no offense if you happen to be one?!?"
Shuto
Maybe its a sign.
gotta have a disclaimer... :)
a sign? what? that they're the same age? you're a sinsita meddler man...
shuto - lol at your drink.. it's got a hairy man bit in it!! :)
i'm flying into kl to see my better half and we're going to nick off somewhere for the week.. preferably driving distance from kl.. tho a short flight/boat ride could be handled...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
