Originally posted by Micko
Ken - twas similar to the cruise we went on when you first introduced me to my R - I remember getting out at the dam with my legs shaking & the smell of burning brake pads:bahaha:
Ahhh yes , the Chris and Ken's Kalamunda to the weir thrashfest.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
My speed cut is still in as well - sucks eh?
yeah?
so how come I hit XXX+5 and had long-forward-neck and then you belted past about 20 kms faster?
I might have taken my foot off at that stage, but not by much!
there was one point when we got stuck behind that 4wd and the car with the canoe on top.... I was fuming! but then we went past that multi and Im sure had I not beendoing 55, I would have been doing something horrifically not-55!!
Originally posted by GTS-t VSPEC
Ken, Not a problem for me, I'll sleep with you:p
On the way home after dropping Aidwin home I was driving enthusiastically at the double ton, hard to swerve left and right to avoid traffic, then the car died, I will still doing a ton and a half! Luckily it was in a straight line. Was it just fuel starvation from the sideways action?
See'ya:burnout:
Died ?
As in rolled to a halt , sputtered once , dash lights came on ?
Be more specific.
Cheers
Ken
Originally posted by zanda
yeah?
GTR's seem to get 200kmh before the limiter comes in.
Cheers
Ken
neo
car has tein coilovers with dodgy-install usingone spacer instead of 2 to try and make it lower!
when it came in it wsa on 35s and was the lowest skyine Ive ever seen. pimpin only - cause you couldnt turn the wheel past 5.
have jacked it up about 5-6 inches to put it through the pits.
now seek to arrange a "compromise height".
Died, as in battery and oil light came on, had to re-start the car while rolling at 150:D
See'ya:burnout:
why didn't you just bump start it ?
Sounds weird, sure you havn't got a loose terminal or something ?
How much fuel was in the tank ?
Cheers
Ken
Aidwin,
I think I still need to sort out my brakes, even once hot there not that great:p
See'ya:burnout:
Brakes , biggest killer of speed.
Trouble with good brakes is they cost.
Go DBA slotted , Castrol srf or AP660 brake fluid with a good bleed and Pagid blue pads in the front with Bendix ultimates in the rear.
Adjust the brake pedal height to take out 90% of the freeplay and viola"
A good brake you can trust.
Cheers
Ken
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
