  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mmm i thought there were more than that being mislead by moir. Pskier is useless at directions - i'll blame him :P
penguin island awww how romantic - does kyles know about this paul haha
ooooo rev210 like the sound of one of those haha could make my car into the batmobile :P
hey Dark
In21th - used to live in busso and my parents have house in bunbury so haha im part country bumpkin too. Dont know who P-plater in whaite line was tho - i thought exactly same thing - he was a little confuddled too.
