  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
alright joey that did it your off my Christmas card list
Come and clean my toilet and all is forgiven....hehe
Oh and a bottle of the sphincter of the universe...aiwaaan heard u say it :)
heheh argg dont be baby! I'll come and clean your toilet :P
ahahah and I'll make sure premium double molt wisky on the way :)
cheers
Joe
