  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
he would be hospital patient if he drives any day like on sunday.
I could not believe him he over took a car doing ***kmph over double lane and another car approaching :)
bad bad move
yeah it sounds like your life shouldve flashed before your eyes then - see im far more tame than that :uh-huh:
paul - i'm hoping so.. i just don't want him to push it real hard a blow things up.. cause i've heard he can be prone to doing that..
as for the new clutch.. am expecting that.. i'm suprised mine still works at the moment.. my driving abilities are not high on clutch care.. hehehe :)
Yeah ive played dangerously with a few cars - SS commodore vs my ZX was the closest call i ever made - geez that was some dumb shit goddamn fun tho haha specially since i chopped him then almost took half his front end off cos i had at the last minute grab his lane or run into the back of grandma doing 60 in a 90
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
