  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
The Pig Drawing Personality Test
The best part about this is that you can forward it round your office and then laugh at everyones crap drawings. We are thinking about setting up a small pig art gallery in the corner of the office here.
Don't cheat by reading the whole thing first. It is hysterical if you do it right!
Get a blank piece of paper , draw a picture of a whole pig on it, not just the head , just a basic drawing though , don't spend too long on it .
DRAW THE PIG BEFORE YOU GO ON.
IF YOU DON'T THE TEST WILL NOT WORK!!
NO CHEATING,
DRAW THE PIG FIRST
HAVE YOU DONE THE DRAWING??
IF NOT, DO IT NOW
IT IS REALLY FUNNY IF YOU DO IT RIGHT!
OK' NOW TO THE INTERESTING STUFF.........
The pig serves as a useful test of the personality traits
of the drawer.
· If the pig is drawn to the top of the paper , you are positive and optimistic.
Toward the middle , you are realistic.
Toward the bottom, you are pessimistic , and have a tendency to behave negatively .
· Facing left, you believe in tradition, are friendly, and remember dates(birthdays, etc.)
Facing right , you are innovative and active , but don't have a strong sense of family , nor do you always remember dates .
Facing front (looking at you ), you are direct, enjoy playing devil's advocate and neither fear nor avoid discussions .
· With lots of details , you are analytical, cautious , and distrustful.
With few details, you are emotional and naive , you care little for details and are a risk taker .
· With less than 4 legs showing , you are insecure or are living through a period of major change .
With 4 legs showing , you are secure, stubborn, and stick to your ideals
If you have drawn more than 4 legs , you are stupid .
· The size of the ears indicates how good a listener you are. The bigger the better.
· The length of the tail indicates the quality of your sex life, and once again the longer ,the better.
Ok, who didn't draw a tail?
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
