  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
well I'll be making my side of bargain Wild Turky I promised... and the Turky you will get!
You will be supprised I hope you have a cage in your house :D hahahahhahahaah
As long as it doesn't gobble , gobble , gobble too much then macka will be happy.
Abit of licking and sucking will please him even more.
cheers
Ken
Originally posted by macka
Cage ? is that for the the sphincter of the universe...
thats ok we'll all wait out the front in the bushes and come out when the parents have left....
Hasn't stopped you hiding in the bushes there before so what's different now ?
Cheers
Ken:D
Originally posted by GTS-t VSPEC
Ken,
Nothing wrong with gun-metal grey GTR's I'll have one if your giving them away:D
See'ya:burnout:
Nope , gave the last freebie to Micko.
Simmo paid dearly for his ( not ):D
Cheers
Ken
cheers
Ken
I dont knowabout sucking but it's kinda Frozen hahhah... he will get freeze burn if he touch with his body...
Paul- I thought you running your car at 1BAR!!! :D
