  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
well I'll be making my side of bargain Wild Turky I promised... and the Turky you will get!
You will be supprised I hope you have a cage in your house :D hahahahhahahaah
As long as it doesn't gobble , gobble , gobble too much then macka will be happy.
Abit of licking and sucking will please him even more.
cheers
Ken
Originally posted by macka
Cage ? is that for the the sphincter of the universe...
thats ok we'll all wait out the front in the bushes and come out when the parents have left....
Hasn't stopped you hiding in the bushes there before so what's different now ?
Cheers
Ken:D
Originally posted by GTS-t VSPEC
Ken,
Nothing wrong with gun-metal grey GTR's I'll have one if your giving them away:D
See'ya:burnout:
Nope , gave the last freebie to Micko.
Simmo paid dearly for his ( not ):D
Cheers
Ken
cheers
Ken
I dont knowabout sucking but it's kinda Frozen hahhah... he will get freeze burn if he touch with his body...
Paul- I thought you running your car at 1BAR!!! :D
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
