  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
only you bring your wife :P ken.
she may be small but I try not to piss her off.
Last time she tried to poison me.:P
She wouldn't come anyway , thinks you lot are way too young to be hanging around with.
Or was she referring to the IQ when she mentioned under 25 ??
Cheers
Ken
Originally posted by Micko
Firstly - let me apologise cos my connection is f u c k i n g slow.
Secondly - sorry Neo, we thought you had left us cos the missus decided she was driving:)
Thirdly - whatever
Take along time for all those signals to get to South Geralton hey Micko. I know how it is.
:bahaha:
Originally posted by 33Spec2
i think nengun was the place EVL_R33 got all his stuff from he said it took ages 4 a reply and when they did reply they didnt even answer his question!
Brent ( thats Nengun ) gets an average of 300 emails a day from all over the world.
Give him a chance , he is good at what he does and it's best to be patient.
Also , don't ask him 10 questions cos he won't answer. One or two is all he seems to do .
cheers
Ken
Originally posted by Adrian_perth
neo, are u getting a titanium muffler? why not titanium catback :P
macka, i am asking fro pricing on trust/greddy cam gears
adrian :P
Yes it is a titanium cat back adrian.
Macka - You are lucky that he tells you about his secret car business. He would not tell u the other night:p
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
