  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
Ken
How are twin turbs setup? to have different spool designs? or to work in unison? Is it feasable to install 2 different turbos one to spool up earlier than the other?
Sorry if it is a silly question.
GTR's run 1 terb per 3 cylinders . Allows to run a smaller terb for faster response.
Supras and RX7 run a small /big terb setup. Small for initial low down spoolup and that then bleeds across to the bigger one. Bit more complicated but can make a torque less motor ( rotary ) very torquey.
cheers
Ken
Originally posted by GTS-t VSPEC
Ken, You still going to Collie?
See'ya:burnout:
yep , have entered , ya still coming.
Will stay at a motel for the night cos it's too damn cold and I'm too damn old to camp outdoors.
cheers
Ken
cheers
Ken
Thanks Ken
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
