haha ken below the belts right :) Paul brought marshmellows - i was what tha? we going to play fluffy bunny or something (put amarshmello in your mouth say fluffy bunny and keep repeating til theres no room left in ya mouth
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Just remember peeps , this is whoretown and everything ( almost everything ) I say is in good humour and I cannot be held responsible for.
If you don't like any comments I make then
Too bad . hehehe
Cheers
Ken
Originally posted by Nizmo
haha yeah i cant believe how many times kyles knocked things over - she was a human bowling ball haha bet troy was probably sulking more when he finds out what a good time she had without him :)
nah i'm use to that she always has a good time without me
And niz check your PM and give us an answer.
I am off to pull a manifold ( the cars , not mine you dirty people ) and will catch you in about , ohhh... 8 friggin hours.
Cheers
Ken
ps bye Liz , remember , the worst they can do is dis own you and is that all that bad ??
we've seen paul drunk - he sleeps haha :) the whole forum has seen that picture!!
Ken u dont offend me haha i would be disappointed if ya didnt have a good sense of humour - people that take themselves too seriously are no fun!!
Buh-bye Liz - sorry once again matey!
Don't worry Troy , it wasn't like we were playing spin the bottle.
* sshhh you lot , don't tell him *
Cheers
Ken
Originally posted by gtrken
No pics , WAAAAAY to incriminating.
Have you rung Kyles to see if she's surfaced ?
I don't want to cos she might think I'm stalking her. * insert evil laugh *
Cheers
Ken
if she had afew and got home at 2ish she want be up till about 3pm
we've seen paul drunk - he sleeps haha :O the whole forum has seen that picture!!
Alas Niz , at my age , a sense of humour is ALL you have.:)
Cheers
Ken
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
