  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
joe, u cheeky basterd upsetting people is jesus's house of love :)
russ i went to st.joesphs(primary) st. norberts(highschool)
macka, if u need my services i suggest u don't let paul come in as his last comment on how he likes chickens up his ass may scare away the only customers we get today!
TODAY GOOD FRIDAY NOONE IS SUPPOSE TO EAT MEAT!
adrian :)
