  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 33Spec2
why cant you go anywhere? haha there is nowhere 2 go here! there is nothing on tv either!
1. everything is closed
2. i am sick (SARS)
3. no-one to take me, no-one to go with
4. i feel like shit
(i just sneezed twice in a row without a break) :)
i made these photochops..
Minh posted them up (Dr GTR)
http://www.skylinesnsw.com/community/showt...hp?threadid=585
then George (xcuzme) made a retaliation thread..
http://www.skylinesnsw.com/community/showt...hp?threadid=608
