  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by rob77
His dad used to coach marcus, my cousin and me privately cos we all looked like going on with it, marcus was the only one that made it, I gave it up to concentrate on my tee scores and I regret that now :D
i did this with golf, sort of regret it but not to fussed as i know i didn't have attitude to practice as much as i would of had to.
3 handicap at age 15
Hi peeps , bye peeps.
Just spent all day on the bloody GTR.
Pulled off inlet manifold cos it had spat No6 throttle body gasket.
Finished at lunchtime , fire it up and found that the rear turbo gasket had gone too.
Have JUST finished. , 4hrs for the inlet , 9hrs for the turbo gasket. Not fun and I'm glad I didn't have to pull off the front one , thats worse.
Anyway , I'm knackered and going boating tomorrow so bye all.
Cheers
Ken
