  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sneeza - took me three trips to marlows before they got it right one day and then they bagged imports in front of me - they just had no clue!! The only time i would go there is to get my car cleaning gear.
Geniune is probably best - its what gets put on my car anyway.
yeah i got those ones u put in the toaster so i put them in the toaster for a little while then chuck them under the griller to make them xtra crispy yummy. Maccas ones are waaaay to greasy!!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
