  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I'm not that short, not compared to you Bayley:p
See'ya:burnout:
Oh well, it must have been me blocking the exhaust then, didn't I tell you I love climbing in car exhausts!
I am allowed to be short Paul, I am a female, you are supposed to be big and strong and protect us girls! I think Nizzy would look after you more than you can look after her!! (hehe!)
sneeza,
oh...
I vote for steak btw. Cook it in a pan with olive oil, white wine vinegar (or wine preferably semillion), crushed garlic,taragon, a tablespoon of whole grain mustard, thinly sliced feild mushrooms and some fresh sliced chilli (if you like the spicy stuff).
You said it Paul, not me!
Jeff used to work across the road from Murdoch at Rocko Boating Centre and we used to see your Skyline and he never used to shut up about it. Dunno why with that Commodore spoiler but he did! I knew when I seen it at Dads that I had seen it before and when you said you worked at Murdoch I put one and two together. Although you spend all day on here so I dunno when you are actually working. How many lectures do you give a week? One?
Dave,
Yeah, Micko and I are both short, but at least I have gone grey yet like him:D
See'ya:burnout:
Give it 12 months and you will be grey with a bald patch in the middle!!!! You are 24 after all!:shake:
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
    • I do this, I also don't get the joke
    • Return flow cooler will be killing you I reckon. You can certainly push more through a low mount setup but they're good numbers for a stock looking engine bay.  Mine made 345rwkw (hub) at 22psi on 98 with a "highflow" on a stock manifold but it's a long way from a normal high flow or standard engine. I used one of those Turbosmart IWG-75's and it was great with the Motec running closed loop boost with pressure being applied to both sides of the diaphragm.
    • Hey man do you have pic of adaptor plate by any chance I need to match up the bolt holes as my gearbox adaptor plate ones are way off the only bolts of starter motor are matching thanks
