  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
liz u grab the autotrader - close your eyes open to a page - point on the page and there u go a new baby :P haha nah Liz you'll know its the one when u see it - actually the car ive got now was my second choice - why i dont know cos it was so much better than the first choice - it was fate i guess :P
No i dont even touch a computer on the weekend if i can help it.
Sorry sould have puta sarcasam thingy on. They are totally busted "pretty"
U should try buying in the quokka, Joe tried to sell his trough that and not the trader at all. And loook how much he took for his!!! u can find a bragain in the quokka but they are not so common in the trader
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
