  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
That is true. I am short, I never have appeared fat but I don't think it would take much for it appear that way. I have always been careful of that!
I am a customer service officer and am on a very quiet day.
No worries Paul, glad to have you back! A relief from the tempory tring to keep your seat warm Kym. I have him to stir now, got lots of good stories on him. I know 3 people who went to school with him.
Diff oil and man boobies, yuck!
