  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
im eating the nicest foccacia mmmm fattening but im sure it'll get worked off - the way people are using me as their shitkicker for Easter - im constantly up n down the stairs in this goddamn building!
But im good cant complain - desperately waiting for 4:30. How are u?
Originally posted by GTS-t VSPEC
Bayley,
I haven't killed him yet, just threatened too:D
Aidwin, I made struts for my last wing:D
See'ya:burnout:
well i've sent that post to the police
if i go missing you get a phone call then u go meet big bubber in the pen and become his little bitch
time off = good
not getting paid for it = bad
It balances out in the end :) But yeah cant wait for this weekend - should have a great time. You get time off to ocmpensate for when u have to work right? Car salesreps work late wednesdays and saturday mornings get a day off in the week to compensate.
Yeah, Kym started that when he brought the Sonata, or possibly before!
Troy, don't worry, I will go witness, Paul isn't being very nice to me so I will dob him in, unless he says sorry first.
4.30, a common looking forward time! I finish then too!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
