  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Bayley,
Of course I take it back, your a realy hottie, I was just upset cause you have a bf:D
See'ya:burnout:
Oh, well thats ok then, I am happier now. Still, you have to earn my trust back now. I will keep being nice though.
Niz, I tell ya, Irenen done it!
tried to order in an adapter for a jap to aussy aerial thing.
would not beleive the bullshit I went through to get some knumbscull to place the order.
"eeeer you'll have to call back later"
"why dont you just write him a ****ing note!?"
" eeeer, ok, but you'll need to come in and make a deposit"
"What? Why? Cause Ive phoned you ten times cause I dont want it? WTF?"
"Im sorry, but you'll have to make a deposit and come into the store before you order it"
"****. I'll just pay for it now with a credit card"
"eeeeer, I'll take the credit card number as a deposit."
"no, I'll just pay for it now. here's the number"
"eeeeer, no. I cant take a credit card payment."
"why not?"
"I'll take it as a deposit"
"why cant i pay for it on the phone?"
"eeeeer, I cant do that"
"sure you can. what happens when you take a mail order?!?"
"eeeer, that's different"
"FOR ****S SAKES YOU LITTLE SHIT!!! YOUR PISSING ME OFF"
"eeeeer...."
...so now some pimply **** has got a card lying around the desk at a busy store with my cc details on it, but only as a deposit. he cant pay for it......
Like ****ing Rainman!!
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
